Cam Swap Issue
Old Sep 12, 2008 | 11:14 PM
Default Cam Swap Issue
I started tearing down the engine compartment of my truck so I can swap my cam today. I had just removed the crank pulley and timing chain cover, I went to grab the chain and it was loose on one side. Now I have to change the timing chain. Do I have to drop the oil pan to change it? If I have to drop the pan do I have to change the oil pan gasket? I have 50,000 on it should I change the oil pump too? Where should I buy it?
Sorry for such a long post, thanks.
Nick
Old Sep 12, 2008 | 11:21 PM
hirdlej's Avatar
Leave the chain alone. All lsx engines have a timing chain so sloppy that it looks rediculous. It's completely normal. Promise
Old Sep 12, 2008 | 11:25 PM
bluecajun5.3's Avatar
11 Second Truck Club
yes, your timing chain should be perfectly fine.
Old Sep 12, 2008 | 11:30 PM
00ChevyScott's Avatar
Wearin' da big hat
Agreed, even my new motor with 16k miles on it was pretty loose.
Old Sep 12, 2008 | 11:35 PM
GMCtrk's Avatar
Do yourself a favor and swap in an LS2 timing chain. It's only $40 and it's much stronger.
Old Sep 12, 2008 | 11:47 PM
Thats wierd. So theyre really loose? Where would you buy the LS2 chain?
Old Sep 13, 2008 | 12:00 AM
hirdlej's Avatar
Is your cam sprocket solid with a goofy bar around half of it or does it have holes in it? My '05 LQ4 had a LS2 timing chain set in it already I don't think it's worth the hassle of dropping the pan and removing the oil pump to change out your timing chain. Leave well enough alone, change the cam and move on
Old Sep 13, 2008 | 12:52 AM
InchUp's Avatar
You know that answer wouldn't work for me...
Old Sep 13, 2008 | 01:02 AM
hirdlej's Avatar
Yeah.....well...... you're "special" lol
Old Sep 13, 2008 | 01:58 AM
InchUp's Avatar
Ya ya ya...you're just jealous of my fishing skills.
