Cam Swap Issue
I started tearing down the engine compartment of my truck so I can swap my cam today. I had just removed the crank pulley and timing chain cover, I went to grab the chain and it was loose on one side. Now I have to change the timing chain. Do I have to drop the oil pan to change it? If I have to drop the pan do I have to change the oil pan gasket? I have 50,000 on it should I change the oil pump too? Where should I buy it?
Sorry for such a long post, thanks.
Nick
Nick
Is your cam sprocket solid with a goofy bar around half of it or does it have holes in it? My '05 LQ4 had a LS2 timing chain set in it already
I don't think it's worth the hassle of dropping the pan and removing the oil pump to change out your timing chain. Leave well enough alone, change the cam and move on
lol
