Cam Suggestions, getting mixed answers.
Old Jul 13, 2012 | 11:16 PM
TheBrettster's Avatar
Default Cam Suggestions, getting mixed answers.
Well I have sort of a special situation. I'm looking for a cam for my 6.0 LQ9. Currently only things that have been done to it is.
Long Tubes
BB Tune
Slightly Ported 317 heads
Built 4L80E (No Stall)
This truck is my daily driver and is meant for the offroad (sand & dirt) So a stall is virtually out of the question.
Now I was thinking about running either the TSP 220/220 with a 111LSA but i heard that would be terrible without a stall. Then I was thinking of a 216/220, again heard it would be bad. Does anyone have a starting point or suggestions?
Thanks in advanced!
Old Jul 13, 2012 | 11:24 PM
WHPLSH's Avatar
Your truck looks like its set up kinda like a prerunner, why are you so against a stall? If you run in the sand you want to get into power as soon as possible? A small stall would make a huge difference. even a 22-2500 is extremely drivable and would get you up closer to the powerband a lot faster.
Old Jul 14, 2012 | 12:49 AM
darnie's Avatar
x2 a stall wont be to bad im running a tr 220 cam and will be ording my stall next week. just get a good cooler, and a temp gauge and tear up some dunes
Old Jul 14, 2012 | 12:58 AM
AndysC3's Avatar
Agreed a 2600 and a low 220s cam will be a nice set up.
Old Jul 14, 2012 | 01:15 AM
Vortec350ss's Avatar
I think with a 216/220 you wouldnt need a stall. I didnt have one with my 222/226 for a long time... and it was fine!
DD is honestly better with the small stall though. It really smoothes out some of the raunchyness that is unavoidable with a larger cam.
Old Jul 14, 2012 | 01:27 AM
Yes the truck is a prerunner. The truck did have a GT2-3 which has been sold.
Justin (BB) told me basically to stay away, I've been through 6 4l80's with this last one lasting 40k so far. Secondly 4l80 stalls are EXPENSIVE. The truck is finally getting geared tomorrow (from 3.73's to 4.56's) which was another issue.
If i can run a 216/220 with no stall that would be ideal. Now if I wanted a choppy idle would a shorter duration achieve that ?
Old Jul 14, 2012 | 01:57 AM
greasemykey's Avatar
i would stick with a 112 LSA that will give you a choppy idle without losing engine vacuum for your breaks.
Old Jul 14, 2012 | 05:30 AM
xdmikey's Avatar
I'm thinking I have a thumper 220/236, Iirc and it's real choppy. It's a DD but it's also a big hunk of weight!
I'm happy w/everything except the rear end sounds I'm trying to diagnose!
Old Jul 14, 2012 | 07:53 AM
AndysC3's Avatar
6 80e's? That's crazy. Do you have a bigger trans cooler?
Old Jul 14, 2012 | 09:26 AM
ltr450ryder's Avatar
That's what I was think wow!
