Cam Suggestions, getting mixed answers.
Old Jul 14, 2012 | 09:59 AM
TheBrettster's Avatar
Originally Posted by greasemykey
i would stick with a 112 LSA that will give you a choppy idle without losing engine vacuum for your breaks.
Hydroboost.
Nope stock trans cooler.
Old Jul 14, 2012 | 11:57 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by TheBrettster
Hydroboost.
In that big truck, you need the 40K cooler. I bet heat killed all of them.
The bigger tires and 3:73 didn't help either.
https://www.performancetrucks.net/fo...ans+cooler+40K
When you get a chance, check out that thread. The bigger cooler will decrease your trans temp and help them live longer.
Old Jul 14, 2012 | 01:12 PM
LS1TRUCKGUY's Avatar
Hydroboost.
DEFINETLEY need a big tru cool 40k.... would have saved you $$$$$$$$$$$$
Old Jul 14, 2012 | 01:22 PM
Chevy_King1500's Avatar
check out the Trucker cams, one from Lunati and the other VHP trucker
Voodoo Cam
# Advertised Duration (Int/Exh): 267/273
# Duration @ .050 (Int/Exh): 217/223
# Gross Valve Lift (Int/Exh): .549"/.549"
# LSA/ICL: 113/109
# Valve Lash (Int/Exh): Hyd/Hyd
# RPM Range: 1800-6400
Trucker cam
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
* LIFT .551/.551
OVERLAP 53*
LSA 115*
POWER RANGE 2000 TO 6200
Old Jul 14, 2012 | 07:01 PM
Gears were installed today, night and day difference. Ordering that transcooler now. I'll forward the cams to justin and see what he thinks. Truck actually moves pretty good now.
Old Jul 14, 2012 | 08:59 PM
1FastBrick's Avatar
Did he send you a computer or an auto cal with new gear calibration???
I only ask because you will get a check engine light if not... Just an FYI
Old Jul 15, 2012 | 12:10 AM
He tuned it in person Monday in Temecula.
Old Jul 15, 2012 | 01:44 AM
Vortec350ss's Avatar
Wow you must ABUSE that thing to crank through 80's like that. A cooler is a must. Judging by the way the truck looks you probably spend most of your time in the mid and upper RPM range when youre playing, so performance off the line is much less important than it is to the rest of us. A higher converter is definitely not gonna help you as much as it would most of us in our 1/4 mile times.
Just curious... but why did you decide to ditch the GT2-3?
Old Jul 15, 2012 | 02:47 PM
felt way too small, lost low end torque.
The transmissions were a result of the tune to be honest. Kept smoking the clutches and blowing up the torque converters. Once Justin put a little bit of torque management back in the trans and lowered the line pressure, this trans has last for 40k so far (fluid still red and smells fine)
Old Jul 15, 2012 | 05:33 PM
That cam does seem to eat up a good amount of low end considering how mild it is. I swear my cam has more off the bottom than that one does... the mid range is better without a doubt and the top end is prolly similar.
It had a very good idle, and broad power curve, but IMO it makes power NA in a similar way to a cam much bigger than it is.
I'd talk to Pat G. Seems like you have a pretty sweet build going, I think its worth it to nail the cam as well.
