Cam Question for 6.0l swap
Old May 4, 2005 | 07:30 PM
Default Cam Question for 6.0l swap
I have a problem with the 5.3, its a rod knock . So me and some buddys pulled the motor and now I'm going to do a 6.0l swap. I want to now what cam I should get. I want it to have a noticable lope but not a helly lope, I want Hp and Tq about equal but a little bit more Tq down low and the power range from 2,000-6.300rpm, I'll have a 2500 stall. I want to be able to tow a trailer up north with no problems (jet skis and snowmobles). My buddy TheLadiesman has a custom crided cam that he was going to use for his 6.0l swap, I can get that if I want its a 218/218 .563/.563 224lsa or I called comp cam and the said a 224/230, I don't now what lift or lsa is but the part number # is 54-444-11 which one should I get, or are there other one, that would work for me. Will the 218/218 be good. Please Help I need it Asap.
Old May 4, 2005 | 09:25 PM
ttt help
Old May 5, 2005 | 09:56 AM
gonzo 6.2's Avatar
http://www.sdpc2000.com/catalog/3876...1-0551-114.htm
Look at this zplus
Old May 5, 2005 | 12:00 PM
BigTex's Avatar
Yes, you'll be much better off with the 218/218 for towing over the 224/230. Low end grunt (under 2000 rpms) will suffer on the big cam. Idle and drivability will be better with the smaller cam too.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
oharajo
Jul 18, 2015 09:24 PM
