cam question
Old May 12, 2013 | 01:32 PM
bbowerman's Avatar
Default cam question
I have a 2001 silverado with the 5.3 its tuned has a cai and exhaust. But here lately I have been wanting to do a little more I found a medium size garret turbo i am buying (family deal) and before I do that I am wanting to change the cam what lift duration can I use on stock valve springs? i dont want anything radical just a little bit more than stock. also do i HAVE to remove the heads to change the cam? thanks
Old May 12, 2013 | 03:03 PM
ChevyRad01's Avatar
No need to remove the heads. Also I would atleast do ls6 springs and hardened pushrods no matter the cam size.
Old May 12, 2013 | 05:08 PM
dmelvin's Avatar
Unless the cam has over .550 or .570 lift... depending on which LS6 springs you pick up, I don't think that the argument has ever been settled on what their max lift actually is.
Old May 12, 2013 | 05:50 PM
Suburbazine's Avatar
There's an easy way to settle it then. .550 is the max lift that is not questionable.
Old May 12, 2013 | 11:14 PM
bbowerman's Avatar
will the lifters fall? i thought they would fall in once i removed the old cam? and the only way to get to them in an ls is to remove heads right?
Old May 13, 2013 | 07:26 PM
zero2sixT's Avatar
They might. Some people use dow rods to hold them in place. And yes you have to pull the heads to get to the lifters.
Old May 13, 2013 | 07:33 PM
Whitecrewcab's Avatar
They are in cups, once you pull the rockers and pushrods out, all you have to do is spin the engine over a couple of times and the lifters should stay held up by the cups. They make a tool that fits in two holes in the front of block to make sure they don't fall, but you can just use good sized dowel rods.
Old May 13, 2013 | 08:15 PM
dmelvin's Avatar
Should, but don't always. I've heard of guys using the dowel rods, I've also heard of people using pen magnets to hold them up.
Old May 14, 2013 | 07:09 PM
low2001gmc's Avatar
z06 cam with ls6 springs. crane also has a boost cam with 551 lift that would work well.
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
