cam question
Old Aug 22, 2002 | 02:10 AM
badride's Avatar
Default cam question
I talked to craig at GTP Racing, He recomended the follwing for my truck. Stage 2 heads and a 222/222-.540/.540 on any lobe seperation i want. Is this to much for a daily driver? i want low to mid range TQ and HP. Good vacum and not to big of a lope with about 400 RWHP. Any suggestions. THAnks
Old Aug 22, 2002 | 07:23 AM
GREGGO's Avatar
Default Re: cam question
Personally, with with stage 2 heads, I would go for more lift. Like around 560 or so. Are you planning on spray? If so, look into a split. As far as lsa, I am looking in the 112 to113 range. Overall, that's not a bad choice and I would run it. I think the first cam I wind up getting will be smaller than that more like a 212/218 530/530 113 or close. But I won't have the head work done for a while.
Old Aug 22, 2002 | 07:26 AM
BigTex's Avatar
Thats a little on the large side IMO for a daily driver truck. But in order to get 400 HP, you gotta do what you gotta do. You will lose torque and you will need to shift @ 6400+. Basically those are the specs for a T1 or B1 cam which alot of the cars run. They don't care quite as much about torque.
Old Aug 22, 2002 | 04:58 PM
oxidizr's Avatar
Moderator / Sponsor
Did Craig tell you what final combustion chamber size would be or what compression ratio he was aiming for? On a 5.3L with those specs and 10:1 compression, I would think you might see more along the lines of 370-380 rwhp...all of this considering you have your typical bolt-ons.
Old Aug 23, 2002 | 12:16 AM
badride's Avatar
We didn't talk about C.R. oxidizer. But i will I'm still in prelims now. Bix tex I was looking at the st.2 heads with the Hammer (C1)222/222 .566.566 114 L/S with 4 degrees of timimg ground in. This may be 2 much then I'm not looking for a race truck just want to have more low and mid range HP and TQ. I'm not going to spray 4.8 Who just put in a cam a few weeks ago? I wanted to see how he likes it after he's had time to drive it awhile. Thanks for the Input..
Old Aug 23, 2002 | 06:27 AM
jlwz71's Avatar
That was me and it still kicks *** <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . You may want to go bigger than I did though. Mine is still VERY streetable with a small lope. I have all the bugs worked out and when I floor it at about 30 mph the *** end breaks loose. It's pretty cool. I am taking it on vacation to the Outer Banks of N.C. the week of labor day. I will see how bad my gas milage sucks then <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> .
By the way mine is a Crane grind. http://www.cranecams.com/motorsports...er/1449521.htm <img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old Aug 24, 2002 | 12:14 AM
badride's Avatar
I was lokking maybe the cam i want will put me to high in the band for what i want..jlwz71 do you still have stock heads? I might go with the 31 to you 21 the only differance is the 31 has a .531 lift would i need to change springs with either one of them?
Old Aug 24, 2002 | 09:59 AM
BigTex's Avatar
You are going to need to replace the springs with any lift over .500 - Jody already has LS6 springs on his truck.
Old Aug 24, 2002 | 02:46 PM
jlwz71's Avatar
My heads were ported a long time ago. It is a home brew job. Smoothed the ports out a little. Did not do a whole lot to them, this was back in 99 when little was known about flow on these heads. You will need Comp 918 springs for that cam. My LS6 springs work just fine with a 6200 rpm limit.
Old Aug 25, 2002 | 01:36 AM
badride's Avatar
Thanks for the help guys this sight is full of good guys..
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
