Cam and Lifter question?
Quick question, I am building a mild 5.3 and I am using a TSP 220 cam. What lifters should I use? Are the stock one fine or should I replace them? Also what springs are you guys running on otherwise stock heads? Thanks in advance.
If the engine is apart and on the stand, I'd put some new lifters in for some relatively cheap insurance. SDPC sells a complete set of LS7 lifters for about $120 I believe, there's a link to their website to the right>>>> As for springs, I'd go with some PAC 1218's, also available from SDPC or Texas Speed
I'd get new lifter trays too, they're about $7 or $8 a piece x 4.
If you're just doing a cam swap in the truck, use the lifters that you have until they give you a problem...you have to pull the heads to replace the lifters.
(Check Texas Speed and SDPC for the PAC springs >>>>
