Cam installed...noisey
Old Mar 12, 2007 | 05:43 PM
bgray's Avatar
TOTM: June 2007
Question Cam installed...noisey
did a comp 212/218 and 918 springs...drivetrain seems a bit nosier..so we dissambled and its getitng adequate lube and torque properly...its just seems a bit louder..not like valve tick or anything..just louder...
is this common?
Old Mar 12, 2007 | 06:06 PM
Grumpy5.3's Avatar
yes some noise is normal but not anything clanging around.... most call it a sewing machine type noise!!!
Old Mar 12, 2007 | 06:11 PM
Mangled03gmc's Avatar
Baltimore Whore
yes it is normal. More seat pressure, stiffer springs.. You are fine
John
Old Mar 12, 2007 | 06:37 PM
Mr. Sandog's Avatar
Don't forget with the 918 springs to allow the motor to get up to operating temp before going above 2000-2500 RPM.
Old Mar 12, 2007 | 07:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Uh, why?
Not that I go tearing off in a cold motor (runs crappy cold anyway) but what occurs?
And yeah...ticktickticktickticktickticktick
Old Mar 12, 2007 | 07:49 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The springs are brittle when they are cold, once they warm up they are more flexible.
Old Mar 12, 2007 | 07:55 PM
trever1t's Avatar
Makes sense, thanks!
Old Mar 12, 2007 | 09:35 PM
bgray's Avatar
TOTM: June 2007
yah thats exactly it..sewing machine sierra~!
Old Mar 12, 2007 | 11:50 PM
Mr. Sandog's Avatar
Yes, the 918 springs are more brittle than the stock, or even LS6 springs. Noisier too.
Old Mar 13, 2007 | 12:24 AM
Wheatley's Avatar
Truck Sponsor
Yes you will hear more noise,that is normal with 918's.They sound like a sewing machine i a way,if you run 918's then you have to get used to it.
I run them and love them
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
