Cam & Drive-by Wire TB
Old Jun 2, 2005 | 05:23 PM
Zick's Avatar
Originally Posted by Okie5.3
grab one of the mail-order tune (core) specials before you do the swap from one of the sponsors ------------->
they can get fairly close so you won't really have the stalling/surging issues. just pop it in when you do the swap. good luck. let us know how it turns out.
I'm going down to Speed Inc once its in, but I may have to drive it for a few days if they can't get me in right away.
Luckly their only about an hr away and its all Interstate.
Old Jun 2, 2005 | 05:24 PM
Zick's Avatar
Originally Posted by BigTex
Set screw on a 2003+ drive by wire throttle body?
Old Jun 2, 2005 | 05:26 PM
Zick's Avatar
It won't matter if you get miles on it or not. When you get it tuned, it will erase all previously learned PCM data.
My cam is slightly smaller than that TR220 and even in my 6L (no TB hole), it loped along and died when I was trying to get it to idle. Without tuning, it would drive me nuts.
Blownchevy's cam has a small intake duration, a big duration split and very wide lobe seperation. That will make idle a non-issue.
I didn't realize they erase all previous data. Just figured they adjusted what was there.
Old Jun 2, 2005 | 05:28 PM
oxidizr's Avatar
Moderator / Sponsor
Oohps ... stuck in the land of 97-2002. Before things got retarded.
Old Jun 3, 2005 | 11:38 AM
BLACKND's Avatar
I had to drill in a small hole in mine to run my comp cam cause it would idle fine until the engine got hot. Once the engine was hot and in a drive gear, it would run fine, but in park or neutral it would die.
Old Jun 3, 2005 | 12:32 PM
Zick's Avatar
Weird, I would have thought it would die in drive rather than park or neutral. Usually the RPMs go up some when in park or neutral vs drive.
Old Jun 3, 2005 | 01:08 PM
BLACKND's Avatar
Yeah, well granted this was with a makeshift tune by a sponser whose name will go unmentioned until I could get to Allens for my proper nelson tune. but yeah. I have heard though that you can get it to run properly with a drive by wire tb if you have it ported without having the hole. I've got one in at Shaners right now testing this theory. I'll let ya'll know the results once I get it back.
Old Jun 3, 2005 | 03:13 PM
Zick's Avatar
Thats cool, keep us updated.
ARC
57
Feb 21, 2022 10:54 AM
greedygenius
Sep 3, 2015 06:51 AM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
