cam and convertor combo
Old Feb 19, 2014 | 02:01 PM
  #31
jmgak47's Avatar
Just get a 212/218 ground on a 110 LSA
Or do a variation 214/216, 212/216, 214/218, 216/218, 212/214...
Because for 4.8/5.3 heads that is way to much split for such a small intake valve...
Also you could use XFI lobes or LSL lobes and go with something like a 214/218 XFI or 215/219 LSL on a 110 LSL, both will chop as much as a 220r on a 112 LSA.
All will chop much more then the off the shelf 212/218 high lift.
Tuning makes a big difference, my 215/222 115+3 in my LQ9 sounds almost stock with my current tune @ 700 rpm. Made a few changes to the tune and only lowering the idle to 650 it will rock the truck back and forth.
Old Feb 19, 2014 | 02:33 PM
  #32
bizle's Avatar
212/218 ground on 110? Wont that really move the power band down and make the top end suffer?
Old Feb 19, 2014 | 02:37 PM
  #33
bizle's Avatar
Seems to me that the xr265hr and the tsp220 will perform pretty close to each other with a 3-3200 stall
I can see the the smaller cam working much better without a convertor but i will be adding a stall and long tubes for sure
Old Feb 19, 2014 | 02:59 PM
  #34
gamble686's Avatar
How high do you plan to spin the motor? Where are you going to shift? 6000, 6400, 6700? I don't like the tsp200 BC these motors benefit so much from a split duration.
Old Feb 19, 2014 | 03:31 PM
  #35
bizle's Avatar
6200-6300 shift points
Mainly just a weekend driver but also maby a few longer trips
i know the truck will run very well with the 212/218 cam but if im spending the money and time i only want to do it once
Also i know this sounds dumb but with the time and money invested i would at least like to hear the cam and people to know its cammed
Old Feb 19, 2014 | 03:47 PM
  #36
1ownerCHEVY's Avatar
Originally Posted by bizle
Keep us posted on your long tubes
i would love to know how big of a pain they are going to be to install? Also how well they perform
Sure will. Ive got alot of info of these forums so im ready to take them on. The hard part will be how to get the truck to the exhaust shop to get my cat less back hooked up to them
Old Feb 19, 2014 | 04:21 PM
  #37
gamble686's Avatar
Very easy. You need a custom cam. The 212/218 is a great Cam and will fulfill 90% of your desires. However I think a 218/222 .565/.571 LSA110 would be the ultimate cam for you combined with a 3200 stall. It will make noise it will make power all the way to your shift points before it falls off and it will make more peak power than the 212/218 and will make more noise.
Old Feb 19, 2014 | 04:23 PM
  #38
bizle's Avatar
im guessing that will be a custom grind rather than a off the shelf?
Old Feb 19, 2014 | 04:29 PM
  #39
bizle's Avatar
I have heard sound clips of the little low lift 265 cam and some sound really well and other sound stock?
I will be running the tsp long tubes and ory pipe no cats
And i have the flowmaster american thunder cat back
Single in to dual out
I know their are better systems out their
But i got this brand new in the box for 101 bucks from a local auction
Old Feb 19, 2014 | 05:40 PM
  #40
gamble686's Avatar
Yes it would be a custom grind.
TSP can get it done for you.
218/222 .563/.566 LSA 110 on XE lobes.
Yeah it would be a good idea to cut the muffler out and toss in a magnaflow or other straight thru. However, it won't kill you.
