cam advancing question
Old Jan 14, 2005 | 11:10 PM
goshawk23's Avatar
Truck addict
Default cam advancing question
i have a 2000 vette cam in my 5.3L with no tq verter or headers. verter is coming soon. if i advance it 4 degrees it's supposed to help with the bottom end right? so where should the dots on the timing chain set be?
i am not a cam guru so all help is invited.
Old Jan 15, 2005 | 06:28 AM
KySilverado's Avatar
Hiya goshhawk. Advancing a cam will move its powerband lower in the RPM range as you mention. You won't line up dot to dot. Done with offset cam pulley bolt bushings, or crankshaft offset woodruff keys. Degreeing the cam to make sure it is spot on.
Old Jan 15, 2005 | 10:28 AM
goshawk23's Avatar
Truck addict
thanks for the info man.
USMCvet0311
Aug 1, 2015 07:45 AM
Castro45
24
Jul 31, 2015 07:13 PM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
