Cam for 6.0 Buildup!!!!
I went with the 216/220 Comp. I use 1.8 rockers and it makes it 555/563 on the lift. I was in the same boat, I didn't want to lose the lowend and lose drivabilty. Mine works really well. I didn't lose any lowend. Now I am going to add a set of stage 2 heads to it.
I'm gonna have Thunder tune the truck. I think I will lose too much bottom end for a daily driver with the TR224 and TB converter.
Originally Posted by BADMOFO
I chose the high lift .212/.218 .557/.56x for the 6.0L I was going to swap. I still really like that cam, but might go for the TR224...especially if you have someone good locally who is going to dyno tune it for you. I would think that idle issues and such would be no problem with a good tune. I think anything larger would jeopardize the drivability of daily usage.
The cam specs look nice except for the 115 LSA. Will they custom grind one with a 112 LSA?
If not I may be looking at the TR220 or the Comp 222/224 at 112LSA.
HMMMM Decisions Decisions!!!!!
Rob
Rob
Originally Posted by Randy Grabert
check out the comp 212/218 56 something lift on a 114 center line you don't want to much dur. are to much center line on a heavy truck. the guys i know that went with any thing bigger than a 220 dur. are more than 114 center line did not have good results in the 1/4 mile.try to get some dyno #'s from diff. set ups good luck i will be able to let you know about the comp 222/224 tomrrow they are going to the track for the first time.
Will the cams mentioned above be ok with a TB converter.
Rob
Rob
Originally Posted by 99silveradoSS
You might wanna call Futral Motorsports, they can help you pick out a perfect cam for your truck. They use cammotion lobes, which are better than comp lobes and give more low-end because of their design. That also allows you to run a little larger cam.
I wish I would have known about them when I was picking out a cam.
Sorry guys I think I narrowed it down here:
Comp: 222/224 .566/.568 112
TR: 220/220 .551/.551 112
I'm unsure if I should get some advance built in. I hope my TB converter likes one of these two.
Let me know guys!!
Rob
Let me know guys!!
Rob
I took your advice earlier. No regrets. The cam rocks on the 6.0L. Idles well!
all_individual
Jul 13, 2015 11:01 AM
