Cam for 6.0 Buildup!!!!
I'm currently in the process of building my 6.0 and can't decide on a camshaft. I constantly read through the archives searching for the right cam. I was looking at the TR224 and 220 but I read that my low end will suffer bad on a street driven vehicle.
It's a 2000 ECSB Silverado 6.0, heads are being milled for 10.8 comp, 3 angle valve job, and pocket porting. I'm running a TB converter and 4.10 gears. The truck will be tuned on a dyno.
I want it to be streetable (idle) and not kill when put into reverse or after accelerating and stop short and engine kills.
Help guys,
Rob
Help guys,
Rob
Banned
Help guys,
Rob
Help guys,
Rob
check out the comp 212/218 56 something lift on a 114 center line you don't want to much dur. are to much center line on a heavy truck. the guys i know that went with any thing bigger than a 220 dur. are more than 114 center line did not have good results in the 1/4 mile.try to get some dyno #'s from diff. set ups good luck i will be able to let you know about the comp 222/224 tomrrow they are going to the track for the first time.
i was running a 224-228-581-588-114+4 and ran a 13.79 n/a. that is with a 5.3 thru a 4l80e. mods lkisted below. i just installed a comp 224-224-581-581-112+4. she feels good. i will get her tuned up soon and take her back to the track.
Hey Randy what's up you probably don't remember me I was the guy at Lesson with Louis a month checking out your trucks and getting the details on the 3 6.0 motors.
Thanks for the help. I really want to know what the specs are on Sammy's cam. As soon as I pick out a cam I'm gonna start putting motor back together. I gonna have to hook up with you guys at No Problem one weekend when truck is done.
The 222/224 your talking about is in Justin's truck right. Let me know if you can find out what's in Sammy's truck.
rob
rob
14 Second Truck Club
You might wanna call Futral Motorsports, they can help you pick out a perfect cam for your truck. They use cammotion lobes, which are better than comp lobes and give more low-end because of their design. That also allows you to run a little larger cam.
I wish I would have known about them when I was picking out a cam.
