bullets to replace cats?
Old 06-20-2009, 03:15 AM
formerly charlyroxs411 (changed 11/19/2012)
LS3powered's Avatar
Default bullets to replace cats?
this is my dilema as for now, i was given 2 3" dynomax bullets and i had recently bought 2 cut outs. i really want the cut outs on the truck so the thing is can i replace my cats with my bullets? the thing is im afraid of using the bullets as mufflers but if i have the cut outs there wont be a diffrence between open or closed cut out with the bullets as mufflers. i still do alot of highway driving. what are your thoughts of this set up: manifold then to cut outs then to bullets(as cats) then the the muffler. let me know what will yall do? sorry if i made it complicated i just need some guidance and help
thanks in advance
charly
Old 06-20-2009, 07:23 AM
PT's Slowest Truck
budhayes3's Avatar
I don't see why you couldn't do that if there's enough room, seems like it may be tight trying to fit 2 bullets and 2 cut outs in the y-pipe. There will be a difference with the cut outs open or closed with the bullets as mufflers, as there will be the extra piping as well as the bullets, which will cancel some of the exhaust noise believe it or not.
Old 06-20-2009, 12:30 PM
LS3powered's Avatar
i dont have a y-pipe, hope these fantastic pictures i drew up will clear things up
Old 06-20-2009, 01:11 PM
Most Hated's Avatar
# 2 looks good
Old 06-20-2009, 07:07 PM
LS3powered's Avatar
anyone else?
Old 06-20-2009, 08:02 PM
PT's Slowest Truck
budhayes3's Avatar
How loud do you want it when the cutouts are closed? Setup #2 looks like it would be loud. I like setup #1...it has the bullets and the muffler so that it's not annoyingly loud at all times, but you can open the cutouts when you want to hear it scream
Old 06-20-2009, 10:14 PM
LS3powered's Avatar
yeah i was thinking of set up 1 anyways, do you yall think it will be louder than what it is right now with cut outs closed with set up #1?
Old 06-21-2009, 09:01 PM
fast84's Avatar
I like setup #1. I think it would be comparable in loudness as current set up. Those cats are pretty straight thru as well.
Old 06-21-2009, 09:07 PM
redsilverado05's Avatar
Set up number 1. Seems like the right way to go. I have The weld race mufflers 3in and 3out with no cats and it gets pretty damn loud when you put your foot in it and it rumbles pretty good at idle too. Also, highway speeds aren't too loud, you wouldn't think it was cammed at all with agressive exhaust cruising between 60 and 70.
Old 06-22-2009, 11:20 AM
LS3powered's Avatar
sweet thanks guys i guess im planning to go with set up #1
Idryfly5
09-02-2022 08:55 PM
lucas287
31
01-12-2021 06:18 AM
Cowboy Tom
09-05-2015 04:29 PM
lxcoupe
09-02-2015 12:58 AM
Fast86z
08-23-2015 12:35 AM
Quick Reply: bullets to replace cats?
