broken manifold bolt
Old Dec 6, 2010 | 07:04 PM
jcsierra0487's Avatar
Default broken manifold bolt
on my 5.3 the back manifold bolt on the driver side has broken off in the head, anyone else had this problem? If so how did you remove it?
Old Dec 6, 2010 | 08:06 PM
mhotrodscooter's Avatar
How about this
https://www.performancetrucks.net/fo...highlight=Weld
Old Dec 6, 2010 | 08:17 PM
scooter k's Avatar
Really common...Sometimes the head pops off and you can use a vise grip or stud remover to get broken piece out. If it is flush try and weld a nut to it.
GM has different bolts with 13mm heads on them to replace 10mm head bolts. I've seen the larger head bolts breaking too. Just did a 08 truck yesterday that had the front and rear bolts on both sides broke.
Old Dec 6, 2010 | 09:43 PM
HitIt's Avatar
Registered User
I am about to do a head swap and have the old style bolts. I would prefer to replace them with something that wont break. Any suggestions? I was looking at the ARP studs but they are $$$ for manifold bolts. Anyone have a parn number for the new style bolts?
Also, I have heard something about drilling the holes on the manifold a bit larger so they wont shear the bolts off when the manifolds expand. Not a lot, just a few thou over. Anyone done this?
Old Dec 8, 2010 | 10:22 PM
Burgundy&TanMan's Avatar
I've had this happen on another guys truck and wound up having to pull the damn head off to be able to get to it!
Old Dec 10, 2010 | 10:23 AM
WhiteChevy3's Avatar
join the club!
Old Dec 10, 2010 | 10:45 AM
TX Tahoe Z71's Avatar
Soaked it in Kroil (industrial strength PB Blaster) a couple of times when the engine was cool and let it soak in overnight, then backed it out with Vise Grips. Took a solid hour, 1/8 turn at a time. But I would soak all of the bolts in some sort of penetrating lubricant overnight at least once so they back out more easily.
zblee
63
Jun 10, 2023 01:25 PM
jfuegner
Dec 22, 2016 03:47 PM
JFortner5
Aug 20, 2015 06:13 PM
4B11T
Jul 13, 2015 03:48 PM
