Brakes acting funny after 408
Old Jun 16, 2007 | 04:28 PM
Lurius's Avatar
Default Brakes acting funny after 408
I was putting off on dealing with this for now, but it nearly got me in a wreck today lol..
Alright.. Ever since I put in the 408(ms3 camshaft) I have had my brakes working kinda funny.. Sometimes I will push them in and it acts like theres no fluid and i have to push it in all the way to stop, like there is no line pressure.. Any idea why? Is it related the vacuum perhaps?
How would I fix this?
-Lurius
Old Jun 16, 2007 | 04:50 PM
nightrunner's Avatar
Mr. Obvious
yes, it is because of lack of vacuum.
swap to a hydroboost setup from a 2500hd truck
Old Jun 16, 2007 | 04:52 PM
Nick™'s Avatar
does your truck have the vacuum pump on the brake booster line like the 2003 trucks? is it reconnected?
Old Jun 16, 2007 | 05:19 PM
RandomHero's Avatar
That's not the problem. The problem lies within the fact that his cam is huge so his truck isn't creating vacuum for the brake booster. I have the same problem with my 5.3L and 224/224 every once in a while. Your truck won't build up brake pressure when you are accelerate and try and stop real quick.
I've had 3 incidents where I had to slam on the parking break in order to avoid hitting the person in front of me.
What you need to do is find a hydroboost setup like Nightrunner suggested. You can find these of all 2500hd/3500hd or most newer SUV's have them there may be other vehicles that have this setup, but you can find them for under $100 if you search on car-part.com or sometimes on ebay.
All you need is the hydroboost, and all lines that go to it. There is one line you'll need to T off of but other than that it's a direct swap, no new master cylinder is needed as well.
Old Jun 16, 2007 | 05:44 PM
Lurius's Avatar
Alright, will it require any special tuning or is it plug and play like most parts for these trucks?
-Lurius
Old Jun 16, 2007 | 06:11 PM
I know what you're talking about, I've had one too many "OH SH*T!" moments with my brakes. I just bought some SS brake lines, if those don't fix it I'm goin on a search for a hydraboost set up. Does anyone have pics of one?
Old Jun 16, 2007 | 07:32 PM
tarinitup's Avatar
9 Second Truck Club
Since were on brakes and 408's I'm having problems with my rear pads running out to quick. I think it's cause of burn outs and I have heard of something called line lock. Anyone using this?
Old Jun 16, 2007 | 09:36 PM
skyhighsami's Avatar
no title here
All a line loc does is bypass the brake fluid to the rear brakes.
Old Jun 20, 2007 | 11:00 AM
CrunkGM99's Avatar
Hey guys, stumbled accross this post almost by accident, and I think I might be having this same issue... Check out my thread here...
https://www.performancetrucks.net/fo...53#post3661153
I would like to get a little more info on the hydroboost setup if possibe...
Let me know what you guys think.
Old Jun 22, 2007 | 05:45 PM
CrunkGM99's Avatar
The problem happened again today... It seems to happen after about 20 miles or so of driving. I guess I'm going to try the hydrobooster. Anyone have a part number? Also, whats involved on the install? Is this a part I would swap, or is it an add in?
Thanks for the help,
CrunkGM99
