braded inline fuel pump line help
Old Jan 4, 2008 | 08:41 PM
ramsey rider's Avatar
Originally Posted by thunder550
I just wrapped it in electrical tape and used the cutoff wheel on my grinder. If you don't wrap it with tape the steel fibers will fray. The tape keeps it all reasonable together.
im with ya ,and yes i just did mine and its a sob .i put my fitting into a vice and pushed the line into it and it took all i could do ,and thread in as youre pushing ,wrap with black tape.good luck.
Old Jan 5, 2008 | 06:38 AM
TG02Z71's Avatar
It is a PITA for sure. Do like Thunder said, don't use the hack saw you will just poke the **** out of your fingers when attempting the assembly and be even more frustrated.
Use a dremel tool with a cut-off wheel after wraping the ends tightly in some kind of tape. I ended up using clear scotch taps and trimmed all but about
1/8" of it off and threaded it into the couplers. If you do leave a small amount of tape on make sure its no more than 1.5 wraps of the braided line.
After you do a couple ends it becomes easy. Good luck.
Old Jan 5, 2008 | 02:09 PM
OrlandoFL4.8's Avatar
thanks everyone, just started up again had alot of stuff to do today; I need more time off lol
Old Jan 5, 2008 | 03:50 PM
Also I just realized that when I went under the truck, I have no room like in the pictures I was going to use for my install and come to find out those pics are for an ecsb now I dont know where Im going to mount this sob
Old Jan 5, 2008 | 05:21 PM
Looks like I might be saying to hell with the braided line, the line just laughed at the new 36 teeth per inch hacksaw blade as it frayed even with the tape and I have enough holes in my fingertips to look like im diabetic and im not going to drop a hundred plus dollars on a special tool to cut this with. I will still use some of my bends and adapters with some rubber hose and since I have no room like the ecsb guys do inside the frame rail, Im going to mount this PITA on the lip of the frame like in the magna charger illustration.
5.3Okasai
Mar 9, 2022 01:07 PM
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
