BMF H2 dyno results
Originally Posted by greentahoe
would the numbers be higher or lower if the converter was locked? At what RPM are you maxing the MAF? What size pulley and how much boost are you seeing?
9 psi boost with a 2.75 pulley. The MAF maxes out pretty low in the 4800 rpm range in the cold air. Locking the convertor makes the numbers higher.
In that case the numbers could be near what I would expect from your setup? How did you compensate for your MAF maxxing? Did you hook up a wideband and richen it up?
Regarding the PE fueling... Past the MAF max I simply kept increasing the multiplier until it met my expectations on the Dynojet Wideband Commander that I tune with.
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
