BigTex-Cam Install Update
Old Aug 6, 2002 | 08:46 PM
jlwz71's Avatar
Default BigTex-Cam Install Update
Let me say this. It kicks ***. Got the truck mostly back together last night at 9:00 pm and fired it up with open headers. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> It sounds great. Finished up today and for the first time with 305/70/16 tires it spun the tires from a 25 mph kickdown to first. It gets up to 110 mph in a hurry also. I am very pleased with the results. Check engine light is on for the P0300 misfire due to the lope but with the stock hole in the throttle body and just HPIII 93 octane tuning it screams. With the Dynomax exhaust I have it covers the lope well but you sure can feel it. Bottom end is better than ever and pulls hard all the way to the 6000 rpm shift point. I have to change underwear now because I jizzed in them from having so much fun today <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Later <img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old Aug 6, 2002 | 09:12 PM
GREGGO's Avatar
Default Re: BigTex-Cam Install Update
Sounds great, are the spec a secret? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Greg
Old Aug 6, 2002 | 09:38 PM
jlwz71's Avatar
Yep, paypal me 20 bucks and I will tell you <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> . It is a Crane grind. Here is the webpage for it.
http://www.cranecams.com/motorsports...er/1449521.htm
Old Aug 6, 2002 | 10:29 PM
BigTex's Avatar
Man thats great -
Ok you have had 3 cams in now? What were they and whats the story on each of them? I have the 01 LS6 and its top end is great, but low end stinks. I want that bottom end grunt. Gimme the info!
Thanks for the update. I will have to give that crane cam some further thought. You say it has some lope to it? ummmmmm I like it.
Old Aug 7, 2002 | 08:19 AM
jlwz71's Avatar
Ok first was the 2001 LS6 cam. Power to high in the band <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> . Took it out and put a 6.0 liter cam from a 2001 engine in and low end came back but power sucked <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> . It was not as bad as the 99 5.3 cam but it still sucked. I really like this one. Lift is not as much as others but I am happy and this one is staying here. I just finally bit the bullet and spent the money. <img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old Aug 7, 2002 | 08:23 AM
AKZ71's Avatar
Is there anything you can do to take care of the check engine light? Other than the light everything else sounds righteous. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 7, 2002 | 08:25 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Glad you found a cam you like Jody. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I wonder how a cam with those same specs, but with about .525 lift would do in a stock 6.0? Hmmm..... <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Aug 7, 2002 | 08:28 AM
jlwz71's Avatar
For the light one of two things. Not let it idle for too long without blipping the throttle or LS1 edit. Or you can do the !SES light mod. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 7, 2002 | 08:38 AM
Jay Johnson's Avatar
I assume your have a 99 5.3L?
Do you think that the cam could tow 5000 lbs pretty good?
Jay Johnson
Old Aug 7, 2002 | 09:04 AM
jlwz71's Avatar
Without a doubt. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
