Bigger fuel injectors for cammed 5.3?
I have an 02 5.3 with a tr224 cam and full boltons. It has stock fuel injectors now. Would I see any gain or do I need to go with bigger injectors? Down the road it will probably get some form of FI or a 6.0, hell maybe both
, what size injectors would I need then? If all that were to happen I'd be shooting for close to 500 at the wheels.
, what size injectors would I need then? If all that were to happen I'd be shooting for close to 500 at the wheels.as for once FI or a different motor I know my Procharger kit for my 6.2L is coming with 60# ls9 injectors.
tr224 is a big cam for a 5.3
I would say the stock injectors are about maxxed out upper 90% duty cycle i bet
TR220 n 243 heads maxxed my stocks out shifting at 6700
I upgraded to 31# regular 8.1 injectors
Yeah if it were a smaller cam and I didn't plan to spin it above 6k I would think they would be fine. I'm going to get it dyno tuned so I guess I will find out. Just hoping I won't have to put bigger ones in after the tune. That being said I don't want to buy a set of injectors just to turn around and buy a different set if I go FI.
What is the optimum duty range for an injector? Will they fail if they are pushed close to their limit? I mean they are not going to see WOT all the time. If they are close to maxed out it should be ok right?
I think 80% isn't stressing them too much for daily use... There are a lot of guys that have seen 100%+ I just wouldn't be comfortable running them that hard. I agree with Graymatter. Go ahead and grab the 60's. They'll be a pain to tune probably for idle, but then you won't have to mess with changing them again when you go FI.
