a biger 4.8
Old Jan 19, 2003 | 03:38 PM
GoldenVelvet's Avatar
Default a biger 4.8
Long time reader first time posting. My truck was born with a 4.8 with the idea that once the truck was payed for I would do an engin swap. No point in upgrading to the 5.3 when your going to swap anyways. My orginal idea was an aluminum 5.7 form an F-body but the more I read the more I find that the truck 6.0 (other than not being alunimum) is the beter way to go. So here are my qustions.
Are any years of the 6.0 beter than others?
(I know the later 4.8s and 5.3s have beter cams)
Whats the best way to deal with the ECM working right and passing Cal smog?
Any hindsight advice you would have if you have done the swap?
Old Jan 20, 2003 | 09:32 PM
Default Re: a biger 4.8
Why hasn't anyone posted a reply? I feel so unloved.
Old Jan 20, 2003 | 09:54 PM
BigTex's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by goldenvelvet:
<strong> Are any years of the 6.0 beter than others? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Take a look at Terminators transmission post for info on 6 liters.
I personally think a true LS1 would be a great swap. Less weight and great power. They are proven performers too.
Dont go too agressive with your cam choice and keeps your cats. That should be fine for passing smog.
Old Jan 20, 2003 | 11:42 PM
CashDudeHomie's Avatar
Do you have to modify the fuel rail to install an LS1? I heard the LS1 has different fuel injectors that are not compatible with the trucks. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 20, 2003 | 11:46 PM
red53gmc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CashDudeHomie:
<strong> Do you have to modify the fuel rail to install an LS1? I heard the LS1 has different fuel injectors that are not compatible with the trucks. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You keep your own intake and fuel rails.
Old Jan 21, 2003 | 06:19 PM
If I went with the 5.7LS1 I would keep the truck intake and maybe the heads also (the truck heads would give a small bump in compretion). However I do not now what will be needed to make this swap. I know the pullies are off and the water pump is different, but, what other things???
I understand that the 6.0 from 2001 up will fit. I dont know about the computer in either of the two swaps.
Any thoughts???
Old Jan 21, 2003 | 06:25 PM
Texas Terminator's Avatar
11 Second Club
don't sweat the computer, you will just have to re-tune it with edit.
Old Jan 21, 2003 | 06:35 PM
BigTex's Avatar
Keep the truck intake, injectors and rails. Unless you went crazy with your cam choice, its very likely that it will run OK without tuning. It will run better with it, but you can drive it just fine with the stock computer. Get it tuned whenever.
I don't think you will have a problem with any of your accessories fitting an LS1. I've heard about the one alternator bolt that doesnt fit, but it wasn't a problem to leave it out. Look for posts by "farmtruc". He put a stock LS1 in his mid-90s truck. It runs 13s with 3.42 gears and no locker.
The 6.0 would be a good choice, but don't think that you'll be giving up lots of power going with an LS1. The LS1 is solid.
Old Jan 23, 2003 | 08:47 PM
The 6.0 seems to be cheaper than the 5.7 (plus I'll need to get ls1-edit)
Does anyone know anyone that had done the 5.7 swap, and has anyone ran the 4.8 computer on a 5.7 or 6.0?
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
hackrst
Sep 2, 2015 05:27 PM
