Which is a better motor for swap
Old Jan 25, 2004 | 07:36 PM
  #21
ktmrider's Avatar
Thanks, Yelo, but I must confess I got mucho info from the F-body guys before turning the machine shop loose. Plus, the whole long block was pretty cheap to start with so there was not as much to lose if I swiss cheesed the block.
Yep, your numbers should come out true. The particular block I have checked out OK after the bore work. Hopefully the casting work at GM is close if others want to go down that route.
Now all we need is to get Lunati and Eagle to start dropping the prices on their stroker kits and we'll be hummin' and strummin' in the trucks!
Old Jan 25, 2004 | 09:26 PM
  #22
2003blue5.7's Avatar
my milage went up with my 5.7 but its hard to tell how much cuz its so fun to get on it. :o)
Old Jan 25, 2004 | 10:25 PM
  #23
gibbs6's Avatar
2003blue5.7, what year did you go with? Also you went just with a Ls1 block and internals right not a Ls6? Ls6 Hp is rated significantly higher, I think is what I have seen.
Old Jan 25, 2004 | 10:39 PM
  #24
I put a ls1 creat motor in. I think its rated at 350 hp
Old Jan 25, 2004 | 10:57 PM
  #25
gibbs6's Avatar
O ok, I think the 02 Ls6's are rated at 405 and then 01's and 00's are 385 if I am not mistaken, but somebody correct me if I am wrong. If there is that much difference between them I may go with the more rare ls6 if I can get a hold of one.
OHsixLS3
Dec 27, 2016 09:30 AM
CammedZ71
Aug 2, 2015 01:44 AM
Rwilliams85
Jul 14, 2015 04:36 PM
davis28905
Jul 8, 2015 03:20 AM
Nimoryan
Jul 5, 2015 03:50 PM
