Best way to vent crankcase
Old Jun 4, 2015 | 04:29 PM
TAPyvehc93's Avatar
Default Best way to vent crankcase
Hey all! I am deleting my PCV on my turbo setup and I decided I just want to vent the crankcase into a vented catch can. Would running a hose off the stock valve cover fittings and off the valley cover (I have a LS3 valley cover) to the vented catch can be enough to adequately evacuate pressures in the crankcase or will those fittings be to small?
Old Jun 6, 2015 | 07:55 PM
Higgs Boson's Avatar
10 Second Club
mighty mouse catch can
Old Jun 6, 2015 | 07:57 PM
rx catch can....I did the monster rx can
https://www.performancetrucks.net/fo...nstall-537579/
Old Jun 6, 2015 | 08:06 PM
niebs's Avatar
i would run valve cover to catch can then to exhaust with a pan evap set up.
Old Jun 6, 2015 | 10:44 PM
Blown06's Avatar
8 Second Truck Club
Pretty similar to how mine used to be set up with the D1sc. I ran a line off each valve cover (I think it was small 3/8" line) to a 1 quart catch can. For the most part it worked, but it was a little inadequate at times especially when I turned the boost up.
I had to do the dipstick zip tie mod to keep the dip stick in it.
Old Jun 6, 2015 | 11:22 PM
GMCtrk's Avatar
ive got a line going.from my.turbo air filter tube to the passenger valve cover. On the driver side, a line goes from the valve cover to a MM catch can (which vents under boost) and is hooked up to the vacuum port on the intake. I do have the pcv valve drilled out.
Completely stock functioning pcv system which also pulls vacuum on the crankcase under boost.
Old Jun 7, 2015 | 09:52 AM
George C....'s Avatar
Formerly ScreamingL
bungs on each valve cover to each catch can for big power setups
laterly -6 line off each valve cover using the existing ports, the valley cover all tie into a 3 way air manifold then into a single catch can
Old Jun 7, 2015 | 02:52 PM
TAPyvehc93's Avatar
Cool! Think thats the way I want to go. Thinking about drilling out the PCV orifice on the driver side too as well.
Old Jun 7, 2015 | 03:29 PM
dirt track racer 81's Avatar
Lines ran down under the truck vented to atmosphere
Blwn99x
Mar 24, 2023 11:14 AM
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
carid
Oct 1, 2015 09:22 AM
the owl
Sep 4, 2015 04:09 PM
