best style cam?
Old May 31, 2010 | 10:45 PM
slowZ71's Avatar
Default best style cam?
Do these motors like single pattern cams, split ??
comparing the LSr 215/223 .604/.610 112+7
OR
TSP 220 .581 112+2
Old Jun 1, 2010 | 09:33 AM
Preston129's Avatar
Split, in almost every circumstance. In stock form, the exhaust flows around 70 % of the intake value, (at least on 243 heads) so the extra exhaust duration is needed. Unless you have a completely unrestricted exhaust (LT, cat-less, dual setup) you're not going to reap the benefits of a single pattern.
Old Jun 1, 2010 | 04:18 PM
slowZ71's Avatar
Well i've seen good dyno's of the single pattern 220 cams. I'm gonna run lt's, catless, single 3" into magnaflow, getting a valve job and a bowl job done on heads.
So your saying to go with the LSr split?
Comp said single pattern cams were good mid-range cams
jdb11386
Dec 3, 2015 09:34 PM
greedygenius
Sep 3, 2015 06:51 AM
Denali08
Aug 9, 2015 04:34 PM
Sexyrado327
Aug 2, 2015 04:08 PM
Kaldar
Jul 27, 2015 06:42 PM
