Best air intake kit?
Old Nov 28, 2004 | 04:09 PM
  #21
SallyDaGMC's Avatar
I like my k&n cai
Old Nov 28, 2004 | 04:17 PM
  #22
slowprocess's Avatar
Originally Posted by 94Teal
where do i get that.. is it really that good?
What he said. Where do we get one at?
Old Nov 28, 2004 | 05:11 PM
  #23
Go to www.ultimatepd.com and you can buy one from there.
Old Nov 28, 2004 | 05:33 PM
  #24
2000 SILVERADO's Avatar
What are the hp/tq gains for it?
Old Nov 28, 2004 | 06:52 PM
  #25
Whistlin00's Avatar
14 Second Truck Club
I like my pro cold
Old Nov 29, 2004 | 09:05 AM
  #26
marc_w's Avatar
Originally Posted by j's01silverado
I never knew so many people liked FIPK so much. I bought the volant because it is more of a true cold air kit than the FIPK. My Volant pulls air from the inner fenderwell through a sealed box. The K&N is an open element with a heat shield. The actual filter is great, the kit itself, I'm unsure. A metal heat shield that seals around the hood in my book is not as effective as a sealed box that pulls air right from the fenderwell. Volant also offers an air dam scoop that pulls air from the lower valance. Great way to get cold air into the engine.
The only thing about pulling air from the fender, is that the rear section of it near the firewall is wide open for hot air to get pulled in.
Old Nov 29, 2004 | 06:32 PM
  #27
I like my airaid (sp?) system so far. great fit, looks nice.
Old Nov 29, 2004 | 11:30 PM
  #28
NorCalLightning's Avatar
I had the UPD on my '01 and loved it! Had an Airaid prior to it and just a K&N panel filter prior to that (I know, I was indecisive). I noticed better throttle response and a bit more get up and go with the UPD. My $.02
Old Nov 30, 2004 | 12:53 AM
  #29
moregrip's Avatar
what a rush!
did they ever get they're quality issue's sorted?
Old Nov 30, 2004 | 01:10 AM
  #30
You know, I'm not sure about that. I got mine in early '02. The only problem I had was that it was kind of a b!tch to get the tube on the throttle body and not bend the cr@p out of the fan shroud. It was a very tight fit but I got it on there (nice and tight). I never had any cracking or finish problems with mine.
A side note, DON'T over oil your filters when you clean them. I did this once and had to pull the MAF and use some electrical contact cleaner on the sensor because I had gunked it all up. I noticed because the idle and performance was all funky and off a bit.
Steve
