BBK's "drive by wire" throttlebody is available!
The new 80mm BBK drive by wire throttlebodies are here! They are built from CNC-machined 356-T6 aluminum alloy and offer quick installation. You will see about a 8-10hp gain to the rear wheels and you can install it with no other modifications required.
Part numbers and pricing are -
1756 1999-02 GM 4.8, 5.3 and 6.0 (with electronic throttle control) - also fits 8.1 $389.99
1757 2003-05 GM 4.8, 5.3 and 6.0 (with electronic throttle control) - now available! $389.99
Orders can be placed online or by calling 1-877-482-9763.(1-508-636-0770 in MA).
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - tbyrne@tbyrne.com
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
Originally Posted by tbyrne
Everything would transfer to the new TB. You'll be all set from there.
I've never taken a good look at the late model throttlebodies to notice if they come apart but I have taken 8.1 TBs apart and the 1756 pictured above will fit an 8.1. Everything usually swaps over.
[url]If we dont see the 8-10rwhp can we get a refund??[/quote]
Can't do that. Most parts don't have a performance guarantee.
You will need a special tool to swap the motor over. At least I did on my 02 drive-by-wire TB when I bought the Shaner TB. It's called a security Torx. Like a normal Torx socket but it has a hole in the middle to clear the raised center. I found a set at Sear's.
You won't be changing the 03+ year models out very easily. The unit is fully closed and held together with rivets. Take a look:
2003+ throttle body on left along side a 2005 LS2 throttle body:
