Backfiring after cam install!!!!!please help!!!!
#51
Make sure all your rockers on tight. I had poor performance after cam and went months not knowing what it was. Finally when I was going to smaller cam the mechanic noticed he had left a rocker loose. Made a huge difference and I kept the cam.
#52
make sure you also got them in 100%
my last heads had a couple bad threads in them, and did the same thing.
backfiring, sputtering, and such.
It was leaking compression around the plugs.
RIght now Im sputtering once in a while...but I just put my heads/cam in and dont have it tuned yet...
I just checked and no codes are being thrown.
Rockers are perfect. Thats what I thought too. All good and tight at 22ft/lbs...
#55
the cam. is it a custom grind? or used cam? reason i ask is cause i had backfire issues also before fro ma custom grind cam, come to find out the cam was junk just after a few miles of use!! oinly difference is i didnt have backfire issues at idle more at 1/4 to wide open, also had the bogging down issues, not saying its the cam just letting ya know i went through something simular
#56
What would be the best way to find this out? Just put my stock one back in there? And it is a used custom grind. The guy came and put just a basic tune in it and it seems like it has more power but still nowhere near enough. Not even close to stock. Its not doing the bogging down at 1/4 throttle anymore either. I think I'm going to put the stock one back in and see what happens.
#59
I just pulled everything out and my harmonic balancer bolt had a lot of metal on it. I'm not sure if it was off the bolt or the crank. I am about to go down to the dealership and get another bolt. I will keep everyone updated.
If you do have it lined up, we need to know the cranking compression. Your cam could be ground wrong too. Did you degree it when you installed it?
