Backfiring after cam install!!!!!please help!!!!
Old Mar 8, 2009 | 12:23 AM
  #41
hirdlej's Avatar
Nothing yet? C'mon we're all anxious to know
Old Mar 8, 2009 | 10:22 AM
  #42
Doing it right now. Sorry was a busy weekend. Give me a few minutes.
Old Mar 8, 2009 | 04:29 PM
  #43
Wasn't the timing. The plugs were really black, maybe fouled out. Not really sure that would cause all this. I also checked all the wires and connectors, none loose. I will check again when I get back home. Wife in being induced into labor tonight. I am really excited. I'll do some more research.
Old Mar 8, 2009 | 04:33 PM
  #44
budhayes3's Avatar
PT's Slowest Truck
Holy cow, you're having a baby tonight! Congratulations!
Don't worry about the truck right now, you're going to be a buzy, sleep deprived daddy for a while!
Old Mar 8, 2009 | 06:28 PM
  #45
make sure you also got them in 100%
my last heads had a couple bad threads in them, and did the same thing.
backfiring, sputtering, and such.
It was leaking compression around the plugs.
RIght now Im sputtering once in a while...but I just put my heads/cam in and dont have it tuned yet...
Old Mar 9, 2009 | 05:42 PM
  #46
04herod's Avatar
i think just from working on the truck with u and the fact that chris likes 2 rig things up and he did do the swap from the v6 to the v8. but kept the v6 harness and just cut n 2 it an made it work i feel u got a wiring problem.
Old Mar 9, 2009 | 05:49 PM
  #47
dlt76028's Avatar
i'm telling you... o2s and or fuel pump.
Old Mar 9, 2009 | 06:17 PM
  #48
04herod's Avatar
its got new o2s n it. the pump was working just fine b4 the cam swap but that is sumthing 2 check.
Old Mar 9, 2009 | 07:49 PM
  #49
dlt76028's Avatar
i would log those o2s and make sure. i had some bosch that were 2 months old that went bad on me. replaced under warranty
Old Mar 9, 2009 | 11:17 PM
  #50
hirdlej's Avatar
What did you cranking compression end up being? I still am not convinced the cam is installed right If you do have it lined up, we need to know the cranking compression. Your cam could be ground wrong too. Did you degree it when you installed it?
