Back again! Too bad this is why
Well it has been quite a while since I have been on here. Too bad it had to be because my truck is dying again. I had put a cammed ls6 in the truck and thought I was done modding for a while. Well after about 30k miles on the motor, it is dying. Anyway there is metal in the oil and the oil pressure is dropping fast. To make a long story short, I kept having a problem with the crank bolt coming loose. I guess it vibrated loose and wallered {sp?} the balancer out. Then balancer bolt was tight but the balancer was flopping around. The best way to explain it was the crank snout was a .30 over piston in a .60 sleeve. I had my three year old with me so I had to drive it home like that to get us home. {about 15 miles} Plus I didnt know that is what its was at the time. I think it may have caused enough vibration to knock out a bearing or two. Anyway I dont know if I should fix it or find 6.0 short block to throw in there. I only have about $2000 to get it going again for now. Any suggestion? Any one got a cheap 6.0, ls2, or ls6 short block for sale?
Would i be better off throwing a crank and bearings in my ls6? Do all the new motors such as the new 6.2 swap right in? I havent kept up with these motors since ls1's , ls6s , ans such. Whats up with a ly6?
the 07+ motors are 58x vs your truck thats 24x.
you can run the 58x in your truck IF you swap to a 24x collector ring, cam gear, or run a 58x to 24x conversion module (275.00) then you have to drill and tap the knock sensors to fit your Gen III knock sensors 11/32 10x1.5mm tap, extend your knock sensor harness to reach the new location. you have an 00 so you'll have to upgrade to a 90mm 4 bolt DBC TB (250.00+) swap your flywheel over to the new motor.
the crank bolt falling out has happened to a buddy of mine. dont re-use the original if you did. try the arp bolt. i guess you can never torque the original tight enough after its been pulled out. always replace it imo. also, i think you could find another 6.0 pretty easily if you dont feel comfortable rebuilding the same motor again. good luck, let us know what you do
zblee
63
Jun 10, 2023 01:25 PM
superchomper2003
Aug 26, 2015 09:39 AM
05GMC4.8
Aug 7, 2015 09:55 PM
