Attn: Peeps with new body 4 door Tahoes...re brakes
Old Oct 29, 2003 | 02:34 PM
Hit Man X's Avatar
Default Attn: Peeps with new body 4 door Tahoes...re brakes
I know those vehicles come with two piston rear calipers. Can someone who has one measure the distance betweent the mounting bolts for me?
Just crawl under it with a tape measure and post up the distance between them...I have an odd idea that they may work on the 1500 trucks.
Thanks!
Old Oct 29, 2003 | 02:52 PM
marc_w's Avatar
Does the Avalanche have these brakes?
I know I've got disks out back... but that's about all I know about them.
I'll have my rear wheels one of these nights. I'm planning for tomorrow. (might have a wheel bearing going bad.)
Old Oct 29, 2003 | 03:09 PM
Hit Man X's Avatar
'Burbans do too, so I'd assume the 'Lanche does also. The bigger vehicles all get 2 piston rears.
Old Oct 29, 2003 | 03:45 PM
marc_w's Avatar
Allright - I'll try to get a measurement from the back-side tonight. If I can't see anything (the backplate, splashguard thing might be in the way), I'll pull a wheel tomorrow.
Old Oct 29, 2003 | 04:50 PM
Hit Man X's Avatar
The caliper is a snap to get to from the back side. Just toss down an old rug and whip out a small tape is all that needs to be done.
Thanks a lot!
If they are the same that means the 2 piston calipers should bolt on to the 1500 trucks
Old Oct 29, 2003 | 08:18 PM
benpimpin1's Avatar
has anyone checked to see if the red painted vette brakes would work?
Old Oct 29, 2003 | 10:42 PM
marc_w's Avatar
No problem!
Yeah, I didn't realize they were that easy to get too. It's a little tight back there, but ahh..... I hope, "extremely close, if not EXACTLY 4 inches", is what you were looking for.
It was a bit of a PITA to stick my head up between the trailing arms or side-links or whatever to see exactly how accurate I was with the tape measure. I had to look at things from an angle. I can get back under there and give it a whole-hearted try with a caliper if needed.
Old Oct 29, 2003 | 10:44 PM
marc_w's Avatar
Ben: I haven't checked them out... I'll keep it in mind next time I'm down my buddy's salvage yard.
Old Oct 29, 2003 | 11:26 PM
Hit Man X's Avatar
Damn, I measured 6.5" between the bolts that hold the caliper to the bracket. Ah well.
Thanks for helping!
Old Oct 30, 2003 | 08:16 AM
marc_w's Avatar
Hold on!
I believe there were another set of bolts - basically the pins on the caliper. Those looked to be about 6-something inches apart.
They (the calipers) were mounted to a wide V-shaped bracket. The wide end looked to be about 6 inches, the other 4 inches - those were the bolts I measured. The bracket itself is only about 2" tall?
So it goes: axle tube to backing plate. Backing plate to caliper bracket - 4" distance on the bolts. Caliper bracket to caliper - ~6" distance on the bolts.
I just assumed that bracket was part of the disk setup, not something that might have been shared with the drums.
Let me try this again.
