asp underdrive pully ,use with e-fans and amp?
Old Jul 23, 2011 | 09:30 PM
getchusum99's Avatar
Default asp underdrive pully ,use with e-fans and amp?
i have the asp underdrive pully and overdrive alt pully. havnt put them on yet. ive been worried about the effect the smaller pully will have on my waterpump and alt. ecspecially when i put my 34 in rad and 05 e-fans on, along with a punch 12. how much will the underdrive pully make when at adle/cruisin with the e-fans on and bass playin?
Old Jul 24, 2011 | 08:36 AM
Petey62782's Avatar
MASS seller approved
I did the swap with a very same setup I have twin flexalites 34 rad and a JL amp that slams power i ran it for two summers with no problems and that was with a 105 alt I later put a 145 alt in because one came up on hear at a good price. I would say run it a until you find a bigger alt but it will be fine until then
Old Jul 24, 2011 | 06:59 PM
cool. did you do the efan harness or did u put a thermostatic switch in?
Old Jul 24, 2011 | 07:49 PM
Petey62782's Avatar
My fan setup from flexalite came with a thermostat switch and it also ties into the ac condenser clutch switch so when the ac is on the fan run and I cam say in this heat the fans run none stop and my amp is kicking and no complaints but this is with the new 145 alt but even with the stock 105 alt I had no problems I just switched it for the added insurance of knowing I could run more without worry
Old Jul 28, 2011 | 07:27 PM
laynejc's Avatar
Depends on your volume. I just got through putting the underdrives on and when the bass hits my amp will shut off at idle like at a traffic light at just over half way up. I have a brand new interstate battery mdp 78, and a kinetic battery running the amp. Runnin down the road I have no problem. Thats my experience.
Old Jul 28, 2011 | 08:35 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
you'll be fine since you have the alt pulley. I've got a 700W amp that I run ***** out & usually run a full 14.4V unless I'm sitting still & it will drop to mid 13s
Old Jul 29, 2011 | 03:30 PM
bgray's Avatar
TOTM: June 2007
DO NOT USE THE FLEXALITE THERMOSTAT! They are grabage, Mine failed on me and left me overheated. Many reported problems with them
Texas5.3_1251
Mar 5, 2016 08:10 PM
wickedRCSB
Oct 30, 2015 09:45 PM
CD82
Oct 23, 2015 07:32 AM
old motorhead
Sep 29, 2015 08:22 PM
hackrst
Sep 2, 2015 05:27 PM
