ASM Header Collector Gasket Size??
Old Apr 24, 2009 | 09:15 AM
Bad_Apple's Avatar
Default ASM Header Collector Gasket Size??
Need to see what size collector gasket I need to buy for my AS&M Headers. Are they 2 1/2 in. or 3 in. collector Gaskets?? And what would be the best to buy paper gaskets or Soft Alum gaskets?? My gaskets that came with the headers got thrown away before I could check them out.
Thanks
Old Apr 24, 2009 | 11:23 AM
BlackGMC's Avatar
Resident Retard
I am pretty sure they are 2 1/2 collectors. I had good luck with the soft alum gaskets with a think layer of high temp RTV.
If you making your own Y-pipe, what i did was weld 2 collector rings together to make 1 thick *** collector ring, that way you can really tighten up and not have to worry about warping it.
Old Apr 24, 2009 | 12:16 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, that dual collector trick that you did was a good idea I agree too, go with the soft alum gaskets and a nice coat of the copper hi temp RTV (it comes out of the tube looking orange)
Old Apr 24, 2009 | 02:58 PM
Bad_Apple's Avatar
Appreciate yall!!
Thanks Clint
Old Apr 24, 2009 | 03:04 PM
thunder550's Avatar
High on diesel fumes
I blew out the paper gaskets and melted the aluminum ones back when I had ASM's. The only ones that I got to last were copper. Since you're supercharged I definitely wouldn't waste time with the aluminum ones, I can almost guarantee that you'll melt them.
Old Apr 24, 2009 | 09:15 PM
02Reaper's Avatar
Get the 2 1/2" copper gaskets.
Stainless Works
13
Nov 5, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
