ASM Header Collector Gasket Size??
Need to see what size collector gasket I need to buy for my AS&M Headers. Are they 2 1/2 in. or 3 in. collector Gaskets?? And what would be the best to buy paper gaskets or Soft Alum gaskets?? My gaskets that came with the headers got thrown away before I could check them out.
Thanks
Thanks
I am pretty sure they are 2 1/2 collectors. I had good luck with the soft alum gaskets with a think layer of high temp RTV.
If you making your own Y-pipe, what i did was weld 2 collector rings together to make 1 thick *** collector ring, that way you can really tighten up and not have to worry about warping it.
(it comes out of the tube looking orange)
I blew out the paper gaskets and melted the aluminum ones back when I had ASM's. The only ones that I got to last were copper. Since you're supercharged I definitely wouldn't waste time with the aluminum ones, I can almost guarantee that you'll melt them.
Stainless Works
13
Nov 5, 2015 03:31 PM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
