ARH 1 7/8 are in
Old 03-15-2010, 02:14 PM
  #41
99 2500's Avatar
I called ARH and they said they will put on the connection for me. I live in central america and getting a tune to remove it is difficult, so would rather just leave it there.
Old 03-16-2010, 10:36 PM
  #42
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by GMCtrk
OEM does not use slip joints because they all leak. It's impossible to get a perfect seal with a slip joint and especially at the collector where the exhaust pressure is very high, one even miniscule leak will drive you crazy.
This is an incorrect statement, my current slip joint StainlessWorks heads do not leak one iota...and, not too long ago, some OEM manufacturers used to use slip joints on their exhaust systems, some still do, and many aftermarket replacement exhaust systems are slip joint. How many slip joint exhaust systems have you installed that have given you problems? You should have PM'd me and I could have helped you out with how to cure that. In the past 25 years I've installed many slip joint exhaust pieces, and always find a way to keep the exhaust gasses in and the tick noises out.
Nice looking headers Michael, they're definitely top quality
Old 03-16-2010, 10:37 PM
  #43
Wearin' da big hat
00ChevyScott's Avatar
Come fix my tick noises
Old 03-16-2010, 10:39 PM
  #44
PT's Slowest Truck
budhayes3's Avatar
Send me a plane ticket brother...and tell my boss why I need the time off
Old 03-16-2010, 10:41 PM
  #45
Wearin' da big hat
I'll come pick you up
Old 03-16-2010, 10:43 PM
  #46
GMCtrk's Avatar
Scott you need to upgrade to some 1 7/8
Old 03-16-2010, 10:44 PM
  #47
PT's Slowest Truck
budhayes3's Avatar
Sweet, that'll be quicker than a plane ...I'll bring some of this...
Old 03-16-2010, 11:14 PM
  #48
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Ive had and isntalled many aftermarket exhaust with slip joints and no problems, I belive its more of a clamp issue than anything. The ubolt clamps SUCK, but the actual slip joint band clamps like supplied with the Corsa exhaust or the walker clamps that a lot of guys go with when building custom stainless exhausts.
Old 03-18-2010, 10:03 AM
  #49
Hunt&Fisherator
silver-mod-o's Avatar
I'm using V-bands on this next exhaust system and Kooks 2"x3.5" headers most likely. Regarding the vibration you have had and mensioned in the first post... Its inside the trans... I heard it and drove the truck...90% sure its the Front pump...
Old 03-18-2010, 10:24 AM
  #50
hirdlej's Avatar
I don't know what Kook's your going to use but the headers I ordered from them have the ball type flanges
Quick Reply: ARH 1 7/8 are in
