Anyone mix in a little E85 in with regular 93??
Old Sep 20, 2011 | 10:07 AM
  #41
BlackGMC's Avatar
Resident Retard
Originally Posted by andrew383
Cant remember where i read it but it's in the pump assembly?
Simple pump/assembly change out???
On your 2007 it is controlled by the tune, there is no sensor... it uses the O2 sensors to detect a lean condition and it assumes that lean condition is caused by E85.
on your 2003, it may have a sensor inline on your fuel line, right next to the tank.
Old Sep 20, 2011 | 10:20 AM
  #42
andrew383's Avatar
traveling mod
So in a sense you could set it up like the 07 if you wanted to run a dual setup?
What about that switchable tune thing KB was working on awhile back
Old Sep 20, 2011 | 10:32 AM
  #43
BlackGMC's Avatar
Resident Retard
are you talking about setting up your 03 like your 07? it won't work automatically on the 03 without the sensor...
the dual tune thing would work, all you gotta do is change your stioch to E85 stioch value and add in some timing
Old Sep 20, 2011 | 07:17 PM
  #44
BlackGMC's Avatar
Resident Retard
Sooooooooooo, today i filled up the tank... This time i did 2.6 gallons of E85 and 20 gallons of 93... I know the tank is 26 gallons that is why i did 2.6 . So far the trims have been averaging +5%, so that is well within tolerances... I will report back my MPG, last tank adding 1 gallon to half a tank i got 1mpg more and that was with no tuning changes...
Old Sep 25, 2011 | 12:03 AM
  #45
Bigschwerm's Avatar
Any updates? The station on base opens next week and will have E85...hoping you have good results!
Old Sep 25, 2011 | 11:07 AM
  #46
kbracing96's Avatar
I ran 25% with 93oct last night at the track. 15psi, 19* of timing and not a hint of knock!
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
jscherbs
Sep 30, 2015 07:54 AM
xxloudogxx
Sep 28, 2015 12:30 PM
