Anyone hook up an after market tach in your 99 up silverado?
Old Feb 20, 2006 | 07:55 AM
Dark Halo's Avatar
Default Anyone hook up an after market tach in your 99 up silverado?
I have an 02 silverado that I need to hook upp an aftermarket tach with a shift light in. Do you guys know what wires I will need to tap into in order to get the tach to work?
Old Feb 20, 2006 | 03:13 PM
SnakeOiler's Avatar
This is really based on what aftermarket company you are using - you should really talk to them. But, according to Autometer web site, if that is what you are getting:
Tachometer Signal Wire Installation
for 5.3 engine(s)
White wire, pin # 10 of the red connector at the PCM. Set as 4 cylinder.
Old Feb 20, 2006 | 05:20 PM
Dark Halo's Avatar
the tach is a faze slim line tach. It should still tie into the same wire on the PCM though correct?
Old Feb 20, 2006 | 05:57 PM
litreddevil's Avatar
Banned
you also can use the white wire behind the cluster.
Old Feb 20, 2006 | 06:57 PM
99Silver6.0's Avatar
Is it a big license plate size tach??
Old Feb 20, 2006 | 07:02 PM
not to jack this thread but how does that work cause if you hook up a timming light it does some wierd stuff like on decell
Old Feb 20, 2006 | 07:03 PM
Dark Halo's Avatar
5" with shift light but it is only 2" deep
Old Feb 20, 2006 | 09:32 PM
SnakeOiler's Avatar
It all depends on what signal the tach is expecting.
Jakejack
Jan 8, 2024 10:44 PM
BKnBLK05
Dec 28, 2015 08:52 PM
05GMC4.8
Aug 7, 2015 09:55 PM
CammedZ71
Aug 2, 2015 01:44 AM
04450r
Jul 24, 2015 01:58 AM
