anyone have a diagram for splicing wires for Fbody injectors?
Old Jun 4, 2005 | 06:35 PM
Banned
Default anyone have a diagram for splicing wires for Fbody injectors?
anyone?
Old Jun 4, 2005 | 08:45 PM
L-EATER's Avatar
11 Second Truck Club
What kind of diagram is it you need? There are 2 wires going to the original truck injector plug from the trucks harness. Cut the truck plug off and splice the 2 wires from the harness to the 2 wires on new plug. Solder the connections and use heat shrink tubing and thats all there is to it.
Old Jun 4, 2005 | 09:40 PM
quicksilverado's Avatar
I think he wants to know if it matters which wires from the harness go to which wires on the injectors.
Old Jun 4, 2005 | 10:41 PM
Banned
that's it exactly quick...thanks for helping, i wasn't sure how it worked at all before, but i didn't want to put the wront wire to the wrong side. thanks for the help.
Old Jun 5, 2005 | 03:14 AM
lm7's Avatar
lm7
xlr8nss had a nice how to on it but icnat find it right now maybe he'll chime in...
Old Jun 5, 2005 | 03:35 AM
Banned
if it's as simple as stated above then it's fairly straight forward. cut, splice, solder, plug, and run
Old Jun 5, 2005 | 03:44 AM
lm7's Avatar
lm7
yeah and shim your fuel rail the fbody injectors are taller.
Old Jun 5, 2005 | 10:05 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
The multicolored (non-matching wires) are the grounds from the PCM. The same-colored (mine are seven pink with one single orange wire) are the 12v leads from the fuse box. Just do something consistent there and you'll be ok (I used red for power).
Old Jun 5, 2005 | 10:22 AM
http://hauln.net/LS1Tech/truck/fuel_injector/index.html
Old Jun 5, 2005 | 11:09 AM
XLR8NSS's Avatar
Adkoonerstrator
That's the page.
ARC
57
Feb 21, 2022 10:54 AM
slowmo934
Sep 9, 2015 12:24 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
