Anyone ever put a 07-08' engine in a 99-04?
Old Jul 3, 2012 | 11:33 PM
chevrolade's Avatar
Default Anyone ever put a 07-08' engine in a 99-04?
What's all needed for this besides changing reluctor
Old Jul 4, 2012 | 12:46 AM
DR132's Avatar
pretty sure the knock sensors are on the side of the block instead of the valley cover.
Old Jul 4, 2012 | 03:55 AM
1FSTMAX's Avatar
Look up smokeshows build thread
Old Jul 4, 2012 | 06:43 AM
scooter k's Avatar
Reluctor on the crank is different also.
Old Jul 7, 2012 | 06:29 PM
LS1TRUCKGUY's Avatar
you can buy a lingenfelter conversion box for the reluctor wheel so yuo dont have to pull the engine apart(unless its already apart)
Old Jul 7, 2012 | 08:57 PM
TXSZ66AVLANCHE's Avatar
I'd change the reluctor wheel rather than use the converter box. For the knock sensors and cam sensor there is more than enough wire in the harness to move, just remove the split loom, zip ties, and electrical tape and pull the wires out and route them to where they need to be.
Old Jul 7, 2012 | 09:03 PM
mitchellmade's Avatar
MASS seller approved
sdpc and many others sell the conversion harnesses for the knock and cam sensor if you dont want to change stock harness also smokeshow helped me out alot with all of my questions I had and was cool about it
Old Jul 7, 2012 | 11:10 PM
jerryls7's Avatar
X-2 true SD has a wiring kit.
thunder550
Oct 8, 2015 04:53 PM
zblee
Aug 3, 2015 03:45 AM
ls2 dude
Jul 25, 2015 11:22 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
