Any of you guys that have done the Ls1 intake swap on our trucks??
Old Feb 24, 2005 | 05:27 PM
01Blackerado's Avatar
Default Any of you guys that have done the Ls1 intake swap on our trucks??
I need to find out whats all involved in this project...I'm trying to get the weiand alluminum intake manifold for the truck!!! Aside from having to shave down the waterpump neck and moding the tensioner pulley but what else is there and who can i get parts from to complete this project?? Thanks fellas
Old Feb 24, 2005 | 05:58 PM
ktmrider's Avatar
Ideally find a Vette/Camaro pulley drive and water pump, should do the trick.
BTW, I read a comparison on the manifolds that included the Weiand unit. There were no significant improvements over the truck model and actually had some big losses in low end. Your 383 and STS should like it tho...
Old Feb 24, 2005 | 06:21 PM
george88gta's Avatar
You will also need to relocate the idler pulley, a new bracket is available from Speartech. New serp belt as well. The alternator bracket has to be cut to clear the TPS and connector. I have some pictures in a 1/24/2005 post ( ls6 intake swap ) in this forum.
Old Feb 24, 2005 | 06:28 PM
Aaah thanks ill search it right now
Old Feb 24, 2005 | 06:30 PM
That and the 150 dual stage Direct Port setup
Old Feb 24, 2005 | 06:36 PM
CashDudeHomie's Avatar
How are you getting the 383 cubes? Are you using a stroked 350?
Old Feb 24, 2005 | 07:27 PM
sleepersilverado's Avatar
in all honestly i would not go with a weiland intake. we have one on a friends car and it is a nice piece no doubt but a real pain to get to seal. also think about the heat soak with it being aluminum and especialy the turbo. that is just my thoughts i would personaly go with one of the composit intakes. but i can not say much about the aluminum issue because i would like to have a sheetmettal intake one day.
Old Feb 24, 2005 | 07:53 PM
XLR8NSS's Avatar
Adkoonerstrator
I think he is getting a 5.3L block bored to 3.9" and stroked with a 4" crank.
Old Feb 25, 2005 | 07:24 AM
Is a 5.3 iron block bored 3.903 and Stroked 4.000 with 6.125 length rods
Old Feb 25, 2005 | 07:25 AM
oops didnt see Xlr8nss's post yeah hes right!!!
