Any engine builders in here need opinions
Old Jan 17, 2013 | 06:39 PM
javier4.8's Avatar
Default Any engine builders in here need opinions
Have the motor at the machine shop prepping for a 408 build. It's either let them put the whole bottom end together or do it myself. Has anyone put one together that can give me some pros and cons about putting one together
Old Jan 17, 2013 | 06:48 PM
TXSZ66AVLANCHE's Avatar
I've put lots of them together, if you have never done one.....don't let the 408 be your first. That's a lot of money to blow if you screw up.
Old Jan 17, 2013 | 06:49 PM
stone150's Avatar
Please elobrate, I know there is a process and a couple specialty tools.
Old Jan 17, 2013 | 06:57 PM
Great attention to detail is imperative, so is cleanliness. If you don't have the proper tools, accurate torque specs (not internet posted specs), angle gauge, and the patience to clean all the oil passages in the block and crank....and check em twice then let the machine shop do it.
Old Jan 17, 2013 | 06:58 PM
Also if you are using aftermarket rod bolts, you need to use a stretch gauge.
javier4.8's Avatar
I haven't done nothing that big but is it possible by just taking time and making sure everything sits right etc
Old Jan 17, 2013 | 07:00 PM
javier4.8's Avatar
I was thinking bout letting them do it. Nad just trying to save some money hahah. I can do everything else from the long block.
Old Jan 17, 2013 | 07:01 PM
Anything is possible, but a stroker kit is a nice chunk of cabbage, your going to hate yourself if you kill the engine on the first startup.
Old Jan 17, 2013 | 07:06 PM
javier4.8's Avatar
Yup true.
Old Jan 17, 2013 | 07:09 PM
javier4.8's Avatar
Now where can I find some bolts for the bottom main. Does arp make them.
