another e fan thread- need some help
dude, do a search under my name
You need to take a needle and stick it into the pin hole because there is a rubber covering over the hole. I snapped my pin in half trying to push it against that.
ya i took a drill bit and removed some of the rubber to get the last one in but no dice. the green wire wasnt attached to the pin as good and the blue and the wire broke off from the pins so im sol
