another e fan thread- need some help
Old Jan 3, 2010 | 03:55 PM
SLOXCAB's Avatar
Originally Posted by GMCtrk
You need to BLAST the wrench with a hammer. It needs to be a quick, massive force. Also, douse the nut in PB blaster.
its soaking right now in some lube but another noob question if your looking at the clutch does it come off counter clockwise or clockwise?
Old Jan 3, 2010 | 03:56 PM
GMCtrk's Avatar
lefty loosie!
Old Jan 3, 2010 | 04:01 PM
SLOXCAB's Avatar
ok cool thanks didnt know if it was different cause of the engine rotating
Old Jan 3, 2010 | 04:12 PM
SLOXCAB's Avatar
GMCtrk you are the man sir thank you for the help and BFH FTW
Old Jan 3, 2010 | 04:26 PM
aaronmc's Avatar
Even with a big *** hammer mine still wouldn't budge. I ended up pinning the belt to a pulley with a C clamp. Finally broke it loose.
Old Jan 3, 2010 | 06:22 PM
SLOXCAB's Avatar
what did you guys use to push the pcm pins down so their even with the rest
Old Jan 3, 2010 | 06:41 PM
SLOXCAB's Avatar
anyone trying to get this done tonight and im runnign out of daylight
Old Jan 3, 2010 | 07:36 PM
SLOXCAB's Avatar
anyone??
Old Jan 3, 2010 | 07:48 PM
GMCtrk's Avatar
dude, do a search under my name
You need to take a needle and stick it into the pin hole because there is a rubber covering over the hole. I snapped my pin in half trying to push it against that.
Old Jan 3, 2010 | 08:00 PM
SLOXCAB's Avatar
ya i took a drill bit and removed some of the rubber to get the last one in but no dice. the green wire wasnt attached to the pin as good and the blue and the wire broke off from the pins so im sol
