Another Cam Question..
Old Dec 29, 2007 | 12:25 AM
WFOsierra's Avatar
I have a 07 5.3 new body style, i am getting ready to install the 212.218 cam as mentioned above. along with the double roller timing set, 580lift ls6 springs and better pushrods. here is a link to what it will souns like.
http://youtube.com/watch?v=lgUETiFfpyw&feature=related
Old Jan 21, 2008 | 03:12 AM
WFOsierra's Avatar
Just finished my cam swap to a 216/220 .560 .560 lift 114lsa and it couldnt have went any better. Love the sound if it anyway... i had to use a LS2 cam sprocket GM part number#12586481 becuase the nnbs 5.3 use a single cam bolt setup. Will post pictures and sound clip soon.
Old Jan 21, 2008 | 07:43 AM
xlcooplx's Avatar
Personally, I'd run a 212/218 with lift under .570" so i could use LS6 springs. You have that TT3000 as well so that'll be a mean little setup IMO
Old Jan 22, 2008 | 02:50 PM
SlvrSierra4.8's Avatar
Sent you a PM....
Old Jan 22, 2008 | 02:57 PM
Mangled03gmc's Avatar
Baltimore Whore
TR220 is a big cam for the 4.8 but needs a 3k stall atleast but it will work. A decent cam would be in the 212-218 or 220 range. Its all how much you want to play the tuning game and what your goals are. Also the 4.8 has a shorter stroke then the rest of the lsx engines.
John
Old Jan 22, 2008 | 08:50 PM
00Silv4.8's Avatar
see and here is where I get the most confused. Yeah yeah the 4.8 is a "small motor" yes, by litres and all but the only difference between a 5.3 is the crank?.. so Im still confused y people see it fatastic to cam the **** outta 5.3s but the 4.8s can only handle small cams? Im gonna put a 221 in and every person who has put a bigger cam in a 4.8 has had nothing but good to say. So now its ur call, cam the **** out of it for a cool sound and some power higher up, or do the smaller cam with a smaller idle, its ur call.
Old Jan 22, 2008 | 09:06 PM
SierraSport's Avatar
Well, I might be buying a new truck so I will be able to do whatever I want to the 2000.. This was my problem, I didnt want my truck to be down for to long.. Now that I am getting the new truck I will pull the 4.8 and put a 6.0 in its place.. Then I will start building the turbo kit.. The New Sierra will be left alone..
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
