Alternator Wire Mod?
#62
Could someone specify exactly where the connections are to be made. I'm trying to match up the write ups with the one picture, and i am confused.
Alternator to battery positive that one i get. the picture on the first page of this thread seems to show two new wires from the positive on the battery, one too the alternator and one off the picture along the fuel rail?
One from the negative to engine (on the side just below alternator) and another ground going from that bolt to the back of the engine off the picture.
i have an existing factory ground going from the negative down to the chassis just behind the bumper, did yall replace or just delete this one by running the negative to that bolt by the alternator?
#64
I just used 4 awg pre made cable they sell for motorcyles;
To go from the alt to the red box,
Non sponsor-
http://www.jpcycles.com/productgroup...C-6E6C0B61D5D5
Non sponsor-
#70
The fusible link from the alt to the junction box is 8ga. The "heavy" cable from the battery to the junction box (and then to the starter) is only 6ga!
4ga all around should be considered a minimum. I really need to take some pictures of what I ended up doing. I did what I thought was a good setup, then added a decent sound system (300W, no sub). Alternator whine! About 10' of welding cable later (in addition to several 4ga battery cables) and no whine. And absolutely rock-steady voltages.
One thing I don't see mentioned often is the handy built-in high-capacity fuse holder in the electrical box. If you take the cover completely off there is a spot for a mega fuse. Autozone just happens to sell 175A ones. I use this for my alternator fuse.
