Alt. Pulley
Old Jan 31, 2003 | 03:30 AM
speeder_08's Avatar
Default Alt. Pulley
my brother-in-law owns an 01 Sierra and got some smaller pulley's a while back. he barely added the alternator pulley a week ago but notices that the volts drop when he is idleing.
My question was about the alternator. should he leave smaller one on or should he go back to stock? which would be better? i also thought i read something about an overdrive pulley, is that just a bigger one than stock and does it work better?
thanx
<small>[ January 31, 2003, 03:32 AM: Message edited by: speeder_08 ]</small>
Old Jan 31, 2003 | 07:10 AM
ArticGMC's Avatar
Default Re: Alt. Pulley
I have a set for mine that I'm going to be installing on my 01 sierra. I didn't size the alt pulley to the stock one but I'm supposed to have the alt pulley that maintains that compensates for the decreased charging level. I'll post my findings when I get back to the house and get them on.
Lar
Old Jan 31, 2003 | 11:59 AM
eallanboggs's Avatar
Drive Pulley = Crankshaft Pulley. Driven Pulley = A/C pulley, P.S. pump pulley, Alt. pulley, Water Pump pulley. Drive pulley: smaller dia. = underdrive, larger dia. = overdrive. You want your crank pulley to spin the parasitic devices that load it down(rob power) SLOWER. You alt is OVERDRIVEN at all speeds above 2k so the only thing your doing above that speed is prematurely wearing out the bearings not making more current. It only underdrives at idle speed which most driving isn't done at idle speed hopefully.
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
