Air raid MIT/K&N drop in
Old Jun 10, 2012 | 07:45 PM
KaOs5582's Avatar
Default Air raid MIT/K&N drop in
Did you guys tune your truck with the new intake set-up like mine? I know the MAF didn't move closer/away from original location, just I feel like its a big change since the tube is bigger and more direct and a better flowin filter, Thanks Crew
Old Jun 10, 2012 | 09:11 PM
pasadenaman's Avatar
All i did was set it and forget it in my 08 ecsb
Old Jun 11, 2012 | 02:48 PM
KaOs5582's Avatar
Well just to be on the safe side, also already havin a Dynotune on the truck and knowing the owners at ARD. I'm gonna get some numbers on paper, too see some numbers.
Old Jun 11, 2012 | 11:24 PM
hawaiianstyle's Avatar
Check out this link, this CAI dyno testing and comparison was conducted by Justin from BBP. This testing was done on a 2008 Silverado 5.3L Flex Fuel truck with factory programming.
https://dl.dropbox.com/u/55742651/In...%20Results.pdf
Old Jun 12, 2012 | 12:02 AM
Brian B's Avatar
Wow, the air raid has good numbers for being the cheapest one in the test. When I installed it in mine, I didnt notice much of a difference over stock except for the great sound.
Old Jun 12, 2012 | 12:35 AM
texasglock23's Avatar
glad I bought airraid last year
Old Jun 12, 2012 | 06:57 AM
xdmikey's Avatar
Where is ARD? I'm looking for a builder/tuner.
Old Jun 12, 2012 | 03:27 PM
Gordy M's Avatar
When you go to a larger intake tube you will change some of the dynamics of airflow the PCM is programmed to look at also if the air is colder because the filter/fresh air/shielding it will change the dynamics/density-in the case, of airflow. That is why it is better to reprogram (Tune) the PCM for optimal performance. Most often the Air intake system becomes louder and most will relate that to better performance. The real test is to hook up a scanner and make a test run and compare before/after results, often the untuned air intake system runs worse. You can do the same on a dyno and at the drag strip, by the scan log will give you more info to optimize real world driving.
Old Jun 13, 2012 | 09:25 PM
KaOs5582's Avatar
ARD Is off of Highway 6 an Addicks-Satsuma, they do everything there and Dynotuning
Old Jun 13, 2012 | 09:29 PM
KaOs5582's Avatar
That's good stuff to know, thanks bro well your really lookin at half the price and same horsepower gain, BIG PLUS in my book
GXPJAY
Nov 5, 2015 06:49 AM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
Codog
Aug 16, 2015 08:23 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
