Ahhhh SOB...
WELL hidy-ho I got it fixed...
INNER pad on driver's right was worn almost to the squeal plate. The noise I was hearing was the anitrattle clips rattling. WTF right?!
Anyway I also found my rear rotors are warped...not too bad but they will be replaced by summers end. Prolly w/ some drilled ones like Mack Daddy has. I need a caliper for that rear also...it's silly to only replace one so I'm gonna get 'Burban 2 piston rears, 'Burban rotors, and all that ****.
Originally Posted by augiedog77
Are the burbon rotors and calipers a direct bolt in or do you need the caliper brackets?
I believe you need the brackets also... ask StupidFast he's the only one with the conversion that I know of now...
Todd@AZPowerAndSound
Jul 15, 2005 08:41 AM
