Ahhhh SOB...
Old May 12, 2004 | 09:23 AM
Hit Man X's Avatar
Default Ahhhh SOB...
Well drove the truck today and sounds like a wheel bearing is going bad.
Is this a common occurance? I dont' think my pads are going south as I have ~70K on the truck now and dont' tow jackshit.
Ideas on cost to fix this? I DO NOT work on breaks due to a few near death mishaps (I've gone 3, and got 2 left)...
Old May 12, 2004 | 09:33 AM
bmbutler's Avatar
I am pretty sure the wheel bearings on these trucks are sealed and you have to buy the whole assembly (not cheap).
I've never had one go out. I wouldn't buy new.....get it from a salvage yard from a brand new truck that just crashed...lol.
Old May 12, 2004 | 09:35 AM
Hit Man X's Avatar
WTF?! Man just what I DON'T want to do is go toss away $300+ for some part like that. (I dunno if the part is $300, but it would not suprise me).
Looks like I'm gonna roll past a local place today and see what the scoop is...it sounds gross to me. It's pretty faint and not too audiable unless you listen well.
Always something...
Old May 12, 2004 | 09:54 AM
MacADaYear's Avatar
Mine did the same thing... then all the sudden siezed... be careful..
Oh yea the dealer stole 260 from me for a new one...
Old May 12, 2004 | 09:57 AM
FLATOP08's Avatar
Hey Hit Man the gm part list for $212.24 so the parts store should have them cheaper. We sell so many of them hubs. Garage price is $148.57 for the GM part.
Old May 12, 2004 | 10:18 AM
Scream's Avatar
MOOBIES Moderator
Does it make a kinda grinding sound, like a hanging caliper or crystalized pads? I thought I needed brakes on my truck b/c of a noise like this, but when I took everything apart the brakes looked fine!
What part is it that you replace?
Old May 12, 2004 | 10:32 AM
FLATOP08's Avatar
Depending how bad it is. They sound like their howling or grinding. We had a couple come in and when you grab the wheel it felt like the lug nuts were loose but the hub(bearing) had that much play in it. The part you replace is where you bolt your wheels too. Which bolts to your spindle. 2WD truck hubs do cost a little more.
MacADaYear's Avatar
Yea.. mine was just like that and kept getting worse over about 2 months... then just siezed. I seemed to notice it more when I was turning and I could feel which side it was binding on.
I could see the "bearing" I guess it was that was inside, it was rectangualar surrounded by like a track. Once stuff starts gettn messed in there it just takes everything out
Old May 12, 2004 | 10:39 AM
Scream's Avatar
MOOBIES Moderator
Can anyone give me part numbers for the correct GM parts to fix this? I have a '01 2WD.
I guess this is as good a time as any...I'm re-hanging my sway bar, getting UCA's and a tranny mount/crossmember for the '80. Might as well do this at the same time.
Old May 12, 2004 | 10:59 AM
FLATOP08's Avatar
2wd part #15112380
4wd part #15112382
frt hub assy numbers
