Aftermarket cam in 4.8L?
Old Dec 2, 2002 | 02:29 PM
Scream's Avatar
MOOBIES Moderator
Default Aftermarket cam in 4.8L?
It seems like everyone on the board that has done a cam swap has a 5.3. Would similar specs apply for the a 4.8, or would I need an even more conservative grind than the 5.3?
Anyone running an aftermarket cam in a 4.8? Any dyno numbers? Thanks!
<small>[ December 02, 2002, 02:34 PM: Message edited by: Scream ]</small>
Old Dec 2, 2002 | 03:01 PM
really slow truck's Avatar
Default Re: Aftermarket cam in 4.8L?
if you wanted a cam "equal" to one in a 5.3L you would need to run less duration because of the smaller displacement
for instance, the 212/218 comp cam works good in 5.3L, 206/212 in a 4.8L(maybe a little bit on the small side though). if i was actually going to buy a cam for mine i would probably try and go with something like a 212 .540ish single pattern on a 112lsa (if i still had the stock converter)
i dont see why more people have done it, not much more than headers but you will get more power from it
Bryan
<small>[ December 02, 2002, 03:02 PM: Message edited by: really slow truck ]</small>
Old Dec 2, 2002 | 08:14 PM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Thunder 2k1:
<strong>check out the ls6 manifold too. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you know anyone that has actually done this swap? In theory it won't perform. But I am reaserching trying it. However, it is a pretty involved swap. belts and fuel systems will most likely need to be reworked.
Greg
Old Dec 2, 2002 | 08:24 PM
why would u say ls6 intake manifold on a 4.8L?unless ur running nitrous, a 3500+ stall, spinning to like 7000rpm with 4.10 gears
Old Dec 2, 2002 | 08:28 PM
greg has to open his mouth. its not fair when what ur planning actually somewhat goes along those lines <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
as for the belts though, what would cause the belts to need to be rerouted. the fuel system is pretty easy to understand i just cant see the other. then again im runnin on like 3 hours sleep <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
<small>[ December 02, 2002, 08:30 PM: Message edited by: really slow truck ]</small>
Old Dec 3, 2002 | 12:58 AM
oxidizr's Avatar
Moderator / Sponsor
The main upper idler pulley would be about 1 1/2" too high and would obstruct the TB/intake. The LS6 manifold sits substantially lower.
Old Dec 3, 2002 | 01:00 AM
gotcha, thanks
OHsixLS3
Dec 27, 2016 09:30 AM
JordanH
Aug 8, 2015 07:59 PM
lycominghunter
Jul 29, 2015 04:24 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
